Configure the Fast Advertisement Interval to send VRRP advertisement
messages. The interval can be between 200 and 1000 milliseconds, and
it must be the same on all participating routers. The default is 200.
Enter the values in multiples of 200 milliseconds.
In the navigation pane, expand
Select VLANs.
Select the Basic tab.
- Select a VLAN.
Select IP.
Select the VRRP tab.
Select Insert.
Select FasterAdvIntervalEnable.
In FasterAdvInterval, type a value using multiples of 200
milliseconds.
Select Insert.
